Connecting amp\sub to factory head unit
I have a 2013 Subaru BRZ. I want to connect an amp to my factory headunit that does not have amp pre-outs. The factory speakers do use factory amps (there's no factory sub).
My question is, I am considering getting the AudioControl LC2i, which uses the speaker outputs as inputs and converts/processes it to a pre-out signal to go to an amp.
But I was wondering if I had a better option since I technically do have a pre-out signal already.
1. Get a crossover/signal processor that will take the pre-outs tapped from my factory amp and convert it to a low signal for subs. I'm not sure if it would be better than using the AudioControl LC2i. I figured it would be better to process a pre-out signal instead of already amplified signal coming out of the factory amps. Any recommendations on signal processors like this?
2. Use AudioControl LC2i and feed it the speaker wires.
Sizzlechest
NJ
57hemi
