enclosure resposes winISD
yes i know.. but is there a limit to the 12-16 inches per cube ft rule
so far flared ports is the only flared ports gets away with cheating that rule
wrong
if you give 16 sq inches to a hifi its going to fall on its face, not enough linearity or motor force to handle that much port are.
Yep, keep port area lower to accomodate for a weaker woofer. ~25in^2 for a 12" Hifi is plety. No need for a 2-2.5ft^3 box with 32-40in^2 of port, because like you said, it'll fall on it's face without enough air spring in the box.
wrong
So im not wrong. IT lacks motor force and linearity, which tells me its a sucky sub. so im right
I like rockford fosgate is ok and they also say 1 3inch diameter port for 1.75cube p1 12 also a low power woofer
lilboom
Car stereo for fun
lilboom
ca
lilboom
