Enclosure not producing
I went to my local installer to have my box built 3.5 cubes internal nice heavy braced box but I can't break the 140 db mark. Was told 140 is easy to archive to I was hoping for more. He said its my equipment not his design. So my question is am I at my limit with what I have or should I look into a different box? Running 2 12" treo ssx powered by power bass xta 5000
Is the box ported? If so, what is it supposedly tuned at? Sounds a little small for a couple 12"s if you're going for SPL. You should be closer to a 150 with 5k and a couple 12"s. What's your electrical like?
post pics of the setup. post up what the amp settings are at. What the subs are wired down to. Gain/Bass Boost etc..
Electrical what is it like.
140 is pretty easy to hit.
Tuned to 36 hz big 3 2 X's power Batts in back 1 under the hood stock alt. Think the box is to small?
[QUO TE =jeffdachef; 8583 365] it can look nice all it wants but if the design is horrible, its not worth a **** thing. Its definitely not your equipment.
Glad to hear it's not the equipment. ...was a little iffy on the power bass amp But I figured for 300 why not
What is the Subs/Amp bridged to? How is the setting on the amp. etc.. all of this. Them Treo's should get loud as hell..
Powerbass amps are pretty **** good for the money.
What car ? First off. Like said. With what you have. A 145 should be easy. Possibly even a 150. Something definately is wrong with what ever the installer has done here dimensions of your box and pics of the amp settings will help
mattspathe
hershey,pa
mylows10
