Enclosure Insulation
the only time u ever use a damper inside of an enclosure is when dealing with polyfill, wool, acousta-stuf, etc...
It is used to reduce the resonance peak inside of a box and extend it's acoustical response lower simulating the design of a lower tuned port or a larger enclosure, however you wish to look at it, for not louder lower bass, but more audible lower bass that is more equal to the rest of the audible frequency range the sub is set to play for smoother transient response.
Any form of sound deadening material should never be used inside of a box nor the outside of it.
ok, was just curious because the spec sheet that came with my sub. giving me optimal enclosure volumes had pictures of said enclosure's with arrows pointing to "sound-absorbing material" on all the inner surfaces.
And why not? Ive seen it done.
JeepBeats96JGC
Master Welder. IWELDSHYT
JeepBeats96JGC
GDEB
csu87
vegang
vegang
