Enclosure Help
big_way32
Am trying to calculate the exact cu.ft for a wedge enclosure. I tried a few different sites and got anywhere from 5.8 - 6.0 cu.ft. Since I needed the exact size I worked it out by hand myself. Here are my dimensions and what i got. Can anyone double check this for me please?
Wedge Design
Outside Dimensions
Height = 22"
Depth 1 = 10"
Depth 2 = 20"
Width = 39"
Formulas used:
Rectangle
L X W X D
Triangle
0.5 (B X H X W)
Since the design is basicly a rectangle and a triangle combination, thats how i calculated it.
I got 4.12 cu.ft for the rectangle and 2.06 cu.ft for the triangle with a gross volume of 6.18 cu.ft.
I also took into account that the 1.5" (0.75" + 0.75") thickness of wood that "attach" the triangle to the retangle along the length was removed and added volume to the enclosure.
Does this sound right? Thanks
Yes at 30 Hz. After sub, port, bracing and my pokets for both my amps on the box(displacement) am looking at 4 cu.ft @ 30 Hz for a Fi Q 15". If i dont like the output then i will more than likely go with a IA Death Row 15" in the same box and see how that does.
big_way32
big_way32
Ocala, FL
big_way32
BP1Fanatic
BP1Fanatic
