dnlpnd
I have two old sub amps, wiring, and three old subs I'd like to build a custom box for and throw in my daily driver. I have 6 cu ft in my trunk available to donate to the cause.
Previously, the two 4 ohm Lanzar Pro 10's (wired @ 2 ohm mono) maxed out my Hi-Fonics Cyclops and a dual 4 ohm voice coil Kicker Comp VR (wired @ 2 ohm mono) maxed out my Kicker ZR-120.
Using both amps, all three speakers, and single box what would be preferential for either a ported design or a band-pass, them to all to share the same air space or keep the 10's separate from the 12"?
Then I also have an old Alpine 7 band parametric that I am wondering if makes sense to throw into the mix upstream of the sub amps. Even though the amps have some low-pass adjustment, the preamp levels and the frequencies to each individual sub amp could be manipulated with the EQ.
Any constructive suggestions would be greatly appreciated.
Thanks,
dnlpnd
- Ported or Band-pass?
- Common air space or separate?
Thanks,
dnlpnd
