electrical ??
jmkanek
if your just gonna be running a factory alt, and a kinetik hc 800 under the hood, would it be beneficial to run 2 1/0 power runs to the back batts, or would 1 run be enough to carry the current needed to charge the back bank
Yea you will definetly want a dedicated ground. You really shoudl run 2 pos, 2 neg at minimum for that amp. And you prolly need more batteries as well. Rule of thumb is 1 group 31 for 2k.
ight thnks man, i gots it grounded in the rear as well and a ground run from the front to back, with the 2 hc2400s ill have two more group 31 batts, appreciate it man
with all that power and a stock alt, i would at least knock out the big 3 til u upgrade that alt and yes, for all of that power a good ground is much needed. nice, clean and scraped bare metal! to the frame of the car
jmkanek
jmkanek
Wise, VA
tommale420
