z0n3d0u7
Im wanting to run 1300wrms in my car, and at the moment it has a 70 amp alt, And a Redtop that im absolutly fed up with [Currently at autozone, charging.].
I have a spot for another alt. So i was thinking about going to a buddy's junk yard, and picking up another big case GM alt. If i get say a 100 amp alt, Will it cause problem's with my 70a alt?
Also, Since im fed up with Optima right now, And have space (Under hood.), Is it possible to run two regular car battery's? I can get them for $10 a peice. I was thinking just try to find two that match up nicley.
Ive also got the option to go get an optima "blem" from a local battery shop for $75 (Maybe they have Odysse blems? they are a dealer.). Friends had better luck with that battery then i have with my new one, And my warranty is up threw autozone, i believe. Only way id go this route, Would be if the warranty my batt.
Theres a place that sells Kinetic, But they tried charging me $500 for a 12" L7.
I had 1/0 Big 3, and redtop, And i was dipping into low 12's / high 11's with just a zx750.1 and a 4ch amp. Even lower with my 1200D.
If i could "get by" with a $30 alt, and two $10 battery's, I'd be able to afford it faster. But if i gotta go buying new batt's, Its gonna take a while.
