electrical questions
if u throw an hc2400 in the back u should be good to go
the kinetik model numbers are numbered by 'how much wattage they support', so hc2400=2400watts supported by just the battery itself.
plus u have the other batt and big 3 in 1/0
u can always upgrade the front battery later on
well i heard a batcap2k is the best for the back in my situation since i dont have a ho alt or a big batt upfront they are supposed to charge and discharge fast
couldnt tell u if an hc2400 discharges any faster/slower....
all i know is plenty of people have stock batteries with deep cycles, etc. in back with no problems
never heard of someone complaining that their battery wasnt discharging fast enough
nsb 90, id like to see a hc2400 fit, ahhh their are alot .
actually just measured the battery and a hc2400 upfront will fit
could i get away with a hc1800
and also should i just put a hc2400 in the front and take out the duralast or wat
well i heard if you dont have the charging to back the batts up they do no good thats why i am wondering with the 130amp alt can it keep up with a batcap2k in the back and a hc1800 or 2400 upfront
Well if you know it all then why listen to anyone? If charging is a problem then dont listen to you shit all the way up all the time.. 2k watts isnt that much.... Get a batt in the back, do the big three and it will probably do the trick..
--I have heard good things on batt caps but IDK about just a battcap to help the electrical, and if you get a batt I dont think you will need one. Yes it charges quick but what if it runs out in the middle of a note? You will know when your batt runs out and you can calm it down for a little while. Let the alt do it or put a charger on it
thats why i am asking if a batcap2k in the back or a hc2400 in the back is the way to go not sure which one i will have around 2200-2400rms
currently have big 3 in 1/0, stock 130amp alt, and gold duralast upfront rated at 1000amp battery
and what ever i put in the back will have pos and neg run of 1/0 from the front
Ill sell you my nsb and all you need is a posi run
king ranch
Banned
king ranch
fl
king ranch
