Electrical question?
i was wondering about my electrical in my car its a 2000 grand prix and i have a yellow top under the hood and the big 3 done in 0 gauge and 0 gauge power wire along with a 160 ho alternator.
i was wondering what else i will need to do to run a ma audio hk4000 and 4 alpine pdx 4.150's in my car
will i need to add extra batteries in the trunk and if so how many, and what else can i do or should that be good not to blow the amps from all the current draw?
so ur saying my 160 amp alternator isnt good i need a bigger one? like how big
also what about adding 2 more yellow tops in the back, would that be good?
im saying if you can get a bigger one, that would be a good idea. however, if its gonna cost you $400 for a 200 amp unit, then no its not worth it.
you will probably need more than 2 yellow tops in the back for that amp. it is known to be pretty **** inefficient in making power and needs gobs of current to back it up.
may i suggest http://www.remybattery.com and picking up as many Deka Intimidator g31 batteries as you can? they will run you $140 a piece plus shipping. that is unless you can get the yellow tops cheaper.
well i can get yellow tops for about the same price right around $140-145 each
also would it be better if i got say a 300 amp alternator or is that just crazy big??? and where is a good place to get one that big?
i kno it sounds like a lot, thats just what i want to do, i mean is it even possible
thats why im askin, you all kno a ton more about this stuff than i do
can i even put somethin bigger than a 200 amp alternator in that car?
no i dont think that i can do that, cuz dont the brackets cost like 200 bux for them and then 2 $400 alternators, thats a grand and i dont wanna spend that much
is it realistic to run all that with a 200 amp alternator 3 yellow tops (1 under the hood and 2 in back) all with 0 gauge?
BassBallin
Banned
BassBallin
jco1385
