electrical help
clouduz
LA
I currently have a kinetik 1800 under hood and a deka 9a31 in the back, sundown 3kd and kicker 650.4 I plan on getting a 250a ho alt from mechman soon. With that setup will I be able to run full tilt for maybe 30 mins at a time. probably won't even do it that much. Oops forgot to mention running 2 ohms each channel on kicker and 1 ohm on sundown. I don't feel like reconing my sub (hdc 12 al) I would like to get another 12 but I know it's better to keep each sub at the same ohms. So my next question is is it okay if I get another d1 sub and have enough power to run the amp at 0.5 ohms without frying the subs? I'm hoping yes due to impedence rise. lol Yet another question....should I run 1 or 2 1/0g from the amp to the front battery or 1 to the front and one to the back? do i need to "upgrade" my stock alt fuse? I currently have the 1/0 going from the alt to the battery fused at 150 (130a alt) stock fuse is the same. I just don't know if that fuse in the fuse box will blow due to way more current.
don't use names and stuff, give us information about like how many watts you're running, not just "Kicker 650.4 at 2 ohms" I have no idea what it would mean.
okay, sorry i'll try to be more informative next time. Kicker = 2 ohms: 170 watts x 4 chan. And sundown = 3000 @ 1 ohm. (not sure how much a .5 ohm) Can some please answer what's the best way to wire from alt. I'm trying to get all possible knowledge so it gets done right the first time. Well I'm off to work, thank you for any responses i get while gone.
clouduz
clouduz
LA
clouduz
