KJThaDon
So I installed my 300 amp alternator in about 2 months ago and have noticed it considerably drops while idle about 1 volt to 1.5 volts and never wants to go back up where it started at. I just figured out why my amp was cutting in and out going into protection, because there is a short in the amp or something. Could this have killed my new alternator?
I have a optima under the hood and that's all
2500 watt amp, pushing maybe 2k at the most. I don't see any reason why I keep having issues with alternators. Could it be something else??
All power and ground are secured perfect with 0 gauge wiring, everywhere.
I just went and had the alt 'tested' at oreillys. The battery tested good and he said the alt is only charging at 12.9 so it's failing..It's a 300 amp from quality power. I had the same issues with a previous 250 amp from another company. What could be the problems? This is driving me crazy. I was about to put a batcap 3000 in the trunk but now I don't even think it has anything to do with the battery..
Any inputs would be appreciated
Thank you!
Thank you!
