electrical gauges
I dont, I just check my stuff every so often, watch for changes in the headlights etc. A lot of people run a volt meter but if you have two+ batts voltages will vary front to back, having an amp temp gauge isnt gonna help much because the temp on the transistors (the important pieces) will be much different from the heatsink of the amp. Most bigger amps dont get super hot that ive noticed.
i picked these up on sale for $10 at MCMelectronics (normally $40). Power Acoustik Meter-4 I wouldn't have paid $40 but for $10 (and free shipping) i had nothing to lose.
Power Acoustik METER-4 (meter4) - Amplifier Monitoring Systems - Sonic Electronix
If i decide to keep these meters, i'll integrate them into the dash trim piece for a seamless look. for now, i am using the DIN mounting cage and everything is secured to the factory radio brackets. Redoing the dash is on my list of things to do -
I calibrated the VU meters by playing a 0dB 1kHz tone CD, then adjusted the levels. The Alpine HU has a constant level analog output on all RCA's when in Ai-Net mode. So I am simply using the VU meters for a relative recording/signal strength indication. Eventually i'll pull from the rear amps and use it for sub clipping levels. Temp is currently HU temp since everything is behind the HU. Thank God Honda gave us sooooo much space behind the dash there.
it comes with a long RJ-45 cable and each meter connects with an RJ-11 - all to one box that also gives you VU meter adjustment. Power, RCA left and right input, and temp input can be located anywhere, but on one location. i've used digital meters (green LCD) previously and it was fine but large and awkward to locate.
KRYPTO
KRYPTO
MN
keep_hope_alive
