BassAndBeer
what size alternator(s) and how many batteries will I need to feed these amps. 9k+rms total since I plan on strapping them at 2 ohms
Dual 350amp alts and 4 3100s batts will do nicely. So roughly $2000 cost wise
And this is kinda one of those things where if u don't know and have to ask, u prly arnt ready to run that much power.
U should read the forums and learn it on own so u don't have to ask simple questions. I'm not try to be a dlck. But check out other people build logs and see what electrical they have and how their voltage is holding up. Check out other people with similar system to what you way to run. Lots of people including myself ran 9k on 4 18s.. Just make sure u keep ur voltage 12.5v and above and u shouldn't have any problems.
My trucks been at the shop for a week. Had to remove my rear ac unit so I could get more air space and build over the wheel wells. And the rear ax is tied into the front ac, so had to get if capped off so I can still use my front ac. Hopefully it will be done in another week.gna take a look at them. hows your new build coming along?
You might check this out to if you havent already ? I been doing alot of research on this for my up grade and also checked in with Mr Massivespl too and a few others lol I will be running Crossfire 8k @.5 ohm to two Fi Team 18s and i am going to run triple alts 2 @ 300 amps and my existing Singer 270 and I have 4 juice box gr 31 batterys and I am ordering Excessive Amperage Alt Nate seems cool and will help you too.what size alternator(s) and how many batteries will I need to feed these amps. 9k+rms total since I plan on strapping them at 2 ohms
Ya me too for about six months then it let the smoke out lol !I ran 6k on a 300 amp singer and 3 D3400s.
You have no idea what you will need until it's installed. Budget for the most and be happy if you don't need it. Start with dual alts.
