Eclipse owners: how many use the "advanced/pro" mode?
kingsxman
Noob in training
I've got a 8445 and love it. However, I wish the "advanced mode" offered a bit more "full" sound to it. I mainly listen to rock and have found that using the time alignment in the standard mode tends to make the overall front stage "fuller" sounding than what I get in advanced. It tends to be very focused...almost like 70 % of the sound is in a tigher dispersion above my dash in the middle of the car. I'm sure thats what they're going for..but I just wish I could readjust it some so the soundstage is wider.
I do perfer the tighter bass from advanced mode and it sounds like the bass is a bit less easy to locate...but overall I dont use it much.
Has anyone else found this to be the case?
Sounds to be like you are hearing differences in the setting between pro mode and regular.
You're bass shouldn't be "tighter" in pro mode, unless you have something adjusted differently between them.
Anyways...with my 8053 I used Pro Mode.
I have the 8455, but I perfer the pro mode as well. The added controls over crossovers make the unit well worth it. I might have a few things to try. You stated that normal feels fuller. You may have a crossover or slope changed that is removing some frequencies. Another thing, the one I am betting on, is that you have circle surround on in normal. If your HU is like the 8455 it can't be used in pro mode. Circle surround is meant to give the illusion of fuller sounding depth from your speakers. I noticed that at low volumes it does a decent job at it.
Good ideas. I have the xover points set the same on normal and advance. (63/hz). I have experimented with the slopes a bit and that seems to mainly affect the bass. The "fullness" I'm talking about is exactly like you described: surround sound. Actually, on the 8445 its opposite: it can be used in Advanced mode but not normal mode. I have tried using it in advanced mode but the music isnt as crisp as with it off. I did however see that there are some things you can do with CS and True bass that I didnt realize. maybe I'll try tweaking that. But I think your on the right track because that is EXACTLY what it seems like the issue is: surround sound.
I believe everyone here has referred to Pro mode and has a deck other than the 8445. I wonder if there is a big difference between the settings you have in pro mode (8455) vs advanced mode (8445).
i have the cd8445, and i dont use the pro mode now, becuase i have crappy pioneer 3 way coax....when my diamond d661s's get here, and i have a set in the kicks and a set in the front doors, ill prally use the pro mode...it distorts my pioneers tho now...so i have it off with the bass on -6 =(
i have an 8053. don't use pro mode right now have played around with it a little. all i have is some co-axials up front. so i'll probaly use it when i get some comps. up front. but yeah it is pretty sweet from what i have used.
When I used the 8445 I believe I ran it in Advanced mode with the CSII on. The CSII, form what I recall gave the music a lot more fuller and defined sound as you have said. I also used it normal with the T/A set to Front, but if you have rear speakers I'm guessing it would sound best with the CSII on. There are also a few settings that you can adjust for the True Bass if I remember correctly. I would also double check that loudness is off....it is the factory default and I think it totally ruins the sound.
On my 8053 I have to used Pro Mode because I'm running active off of it.
John, you are the man! I actually went and spend a bit of time with this yesterday. I always ran CSII off as it sounded just goofy with it on. This time, I turned it on and then went in and changed some other settings: mono to stereo for bass, phase, readjusted EQ. Your right about not being able to set the TA for "front". However, I dont really need it as it sounds good without that adjustment. Long story short....it now is sounding better than normal mode. One of the great things about these Eclipse decks is all the settings you have access to. It's also a pain if you dont spend the time on it.
Where is the loudness control? I dont recall seeing that.
kingsxman
Noob in training
kingsxman
Minneapolis
kingsxman
