dvc wiring question
You mean dual 4ohm. The answer is no. A dual 4 ohm sub can be wired in parallel @2ohms or series @8ohms. The benifits of dvc speakers are scene when you have multipe speakers being connected to one amplifier. 2 dual 4ohm speakers can be wired to achive a 4ohm load. Also 3 dual 6ohm speakers could be wired to get a 4ohm load. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif . Why do you ask?
i was asking cause i want to bridge my sub to to a 4 channel amp, but plan on upgrading to a mono sub amp when money permits.Dont want to get two different subs.
Ok I just ordered a DVC 4ohm sub. Now I am going to order a mono amp that puts out 300x1rms @ 4ohms and 420x1rms @2ohms. What you guys are saying is that I can't wire a DVC sub to see the 300rms @ 4ohms? So with a mono amp I need to go with a SVC then? Will it not be as loud or clear, etc? Thanks alot. Oh and my sub is 350rms/650max.
Ok, I guess thats what I'll be doing. Thanks.
Another question about wiring. I have some 6.5s that apparently handle 40watts rms a piece( I thought they were going to be 80 a piece, not total). I have an amp that puts out 75x4rms @ 4 ohms. Should I run the 75 to each 6.5 or should I try and split one channel to both subs? Thanks alot.
If the amp puts out 420watts@2ohms then a dual 4ohm sub wired in parrallel is best.
95RAM
95RAM
Jensen Beach, Fl
indosia
