DVC can be wired at 2ohm and 8ohm
cory51191
Cory
The Rockford Fosgate page only shows DVC wiring options for 4ohm or 1 ohm but my amp manual shows a way to do it 2ohm and 8ohm.
This is exactly what it says, word for word.
Parallel voice coil wiring (2ohm operation): To wire a DVC subwoofer in parallel in order to get 2 Ohms, use 2 short pieces of speaker wire and link the positive of one coil to the positive of the second coil and do the same for the neg coil. Then wire the amplifier to opposite sides of the subwoofer in order to equalise any connection resistance.
Series voice coil wiring (8ohm operation): To wire a DVC subwoofer in series in order to get 8 Ohms, use one short piece of speaker wire and link the positive from one voice coil to the negative of the second coil. Then wire the amplifier to opposite sides of the subwoofer.
Sounds like one is a D2 and the other is a D4 //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
would it be smart to get 2 12"s thats wattage rating (paired together) will be higher than the amp's wattage rating?
You will underpower them but it'll be safe. You might want more power later though. And remember to match RMS rating, not MAX rating //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i'm just going to order 2 of the fusion 12" competition subwoofers, PP-SW120.
i can get 2 of them $240 shipped with 1 yr warranty
cory51191
Cory
cory51191
Worcester County
cory51191
