R Record Holder07 10+ year member Senior VIP Member 468 0 H.H.I. Jun 24, 2006 #1 Need assistance wiring (1) DVC 1 ohm sub. The amp is a HCCA-D5000 and I plan to run it at a 0.5 ohm. How do you correctly wire the sub? Click to read more...
Prowler573 5,000+ posts R.I.P. Gossamer!! 18,973 115 Northwest Louisiana Jun 24, 2006 #3 Like this (disregarding that this diagram is labeled for a DVC 2 Ohm driver as the wiring method is still correct for your desired result):
M mtlhead 10+ year member CarAudio.com Veteran 4,819 1 Columbus, Ohio Jun 24, 2006 #4 pos (amp) to pos(coil) to pos(coil) neg(amp) to neg(coil) to neg(coil)
OP R Record Holder07 10+ year member Senior VIP Member 468 0 H.H.I. Jun 24, 2006 Thread Starter #5 iight guys thanks...I appreciate all the help!
OP R Record Holder07 10+ year member Senior VIP Member 468 0 H.H.I. Jun 24, 2006 Thread Starter #6 prowler you don't have to reply to that last PM then...thanks a lot man
Mike yayo 10+ year member Chevy Ridin on 24s Ya Dig 279 0 tampa Jun 24, 2006 #7 is it ok to run 1 ohm for daily use?
Prowler573 5,000+ posts R.I.P. Gossamer!! 18,973 115 Northwest Louisiana Jun 24, 2006 #8 If the internals are basically the same as the 2500D that it replaced then it should present you with no problems //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
