Dual battery wiring tutorial (and why)
No, they don't have to be the same battery. Some will tell you this will shorten the life of them if you don't use an isolator, however I've never used one and I'm still using the used yellowtop I bought over 4 years ago so take that as you will....
Adding a second battery will put more strain on your alternator but the problem isn't necessarily adding the battery it's the underlying problem of you drawing more power than what your alternator can produce. If your just running that 1200 and 300 (1500w total?) you're on the brink of needing an aftermarket alternator. Depending on the stock size you could probably run it for awhile with the two batts but then you run the risk of totally killing the alternator at some random point in the future which will leave you stranded without a car....
Thanks for clearing that up. I might get my alternator either rewound or buy an aftermarket one. Any reputable companies besides DC alternators to buy from? How are the ones on ebay?
I believe the other recommended company is Mechman but I have no experience with them so I can't vouch for them. Same with ebay, I wouldn't personally buy an alt from ebay but I believe there's members on here that have. You'll just have to search around, you'll find your answers.
838
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
832
940
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
loopkiller
PERMA-BANED
loopkiller
Glass City
Dxtr315
    May 16, 2024
    May 16, 2024
