Ds 18 amps, good or not
If I am not mistaken, DS18 is a house brand from a distributor out of Florida. I can not recall who else they rep but I do recall reading something about them on CEoutlook.com. They were at CES in the north hall behind the I heart radio booth.
Not much to look at and I didn't see any literature on ther offerings.
Good move on the soundstream, the ds18 frx1k is the worst amp I have every used, now the atom amps are good for the doors and take up the space of one amp, I have them pushing ds18 6x9 and 6.25, massive door tweeters, by them selves they sou d good for what I listen which is everything from ocean sounds to hard rock.....and they can take a pounding, so they're not all bad...
Back to the frx1k,......POS .....in my opinion, boasts 1000w rms @ 1ohm...and couldn't handle 1 old school rockford 10 inch sub at 500w rms on the sub......then I put my 12in memphis m6.....running on a flat signal clipped......then my friends oscilloscope confirmed it was a total pos. the dyno rated it at 375w rms max at 1ohm, 200 @ 2 ohm, 156 @4 ohms..........then we put a sub on it and played thunderstruck the amp never made it past the 3rd bass drop....RIP...
177
423
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
acesaines
acesaines
Australia
Slo_Ride
    May 18, 2024
    May 18, 2024
