Drill through firewall on pathfinder
what kind of car? what side is the battery on?
Did you read the title before you clicked???? If the pathfinder is at all set up like an Xterra look behind the glove box, there should be a grommet big enough to slice and push the wire in.
Found a piece of metal that was blocking a hole on the drivers side. Had to remove some stuff under the dash to take it out but I'm all set now. I just got a deka yesterday, should I be putting a fuse in between the deka and my starter batt?
I guess this is why I wear glasses. My bad double I must've completely overlooked it
---------- Post added at 11:36 AM ---------- Previous post was at 11:35 AM ----------
Yes you should.
what fuse size? i have a 150A from when i didn't have the extra batt in but i feel like i may blow the fuse..
pushing 1500w @ 13.8v, all the "heavy duty" wiring is done with 1/0 shok CCA
Kangaroux
I put on
Kangaroux
Maine
Kangaroux
