drill it in
install the sub.
flip over the gasket( from the cone side, fold it over, your gonna have to use some force), make shure the holes are lined up, drill in a screw.
that way you can see if you hit the surround or not.
If you just drill in then your gonna mess something up
install the sub.flip over the gasket( from the cone side, fold it over, your gonna have to use some force), make shure the holes are lined up, drill in a screw.
Never done this, and NEVER had a problem. Line the gasket up with the holes in the basket, mark on the box, remove driver, drill holes, run screws in then back out, reinstall driver, screw in screws with a screwdriver, done.
visualize :
you insttall the woofer.
you line up the gasket and the woofers holes.
Take the gasket in your finger tips, the cone side.
fold it back untll you can get a screw in there, through the basket and the gasket.
Screw it in.
then do the opposite side to keep the gasket from moving.
Do you get it now ?
P.S
install the woofer,mark the holes, remove woofer, predrill, follow steps above
nah dude..way too much work..
can u see thru the holes right now? i mean, look at the sub...can u see thru all the holes? (like u put ur finger on the other side..can u see ur finger thru the holes?) if u can..ur set..if not...turn the rubber gasket until u can..
drop the sub in the box, mark ur holes..predrill...screw it down...that simple
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
italianlifter17
italianlifter17
ohio
Tirefryr
