Door speaker instal
MemphisLove.
Im have no clue on how to get the 16 gauge wire through the passage way between the door and body of the car. can anyone help? Its that little plastic bendy part that houses the wire for the windows and such. i tryed popping it out but i cant. i cant get it cause my fingers are too fat //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif.
impossible to do on some cars
I know. My rubber boot has a plug on the chassis of the car. The plug is near impossible to remove with the door still in place. If you do manage to pry it off you cant just push a wire through it.
I ended up going to the sunroof drain then cut a hole in the rubber boot
impossible to do on some carsI know. My rubber boot has a plug on the chassis of the car. The plug is near impossible to remove with the door still in place.
my car is impossible/ has the boot cant pry it off.
suzuki forenza. im using the stock wire from inside the bootbut then using 16 gauge the rest of the way. but the stock is 18 gauge. will it be bad if i do this?. 50watts going through the 18 gauge. im expecting it to be fine.
mm and grease it up too.. i cuffed wit the wiring for mad long but then i used some petroleum jelly and was done in a minute
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif :eyebrow: //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif :eyebrow:
Edit: I think thats sig worthy
MemphisLove.
MemphisLove.
PCB, Fl.
chibahawk
