Okay will someone just check out what I want to run?
I've got an 18G wire running direct off the battery that I want to connect into:
-2 CCFL tubes running on a switch
-4 CCFL tubes and a Music Interface device running off a switch
-4 PC fans in amp rack
-2 amps
I'm doing all this through the standard SPDT or SPST Relay.. wondering if 18AWG is good enough for all this stuff and whether or not I have made any mistakes in how I should probably wire it.
Enjoy the diagram.. im bored as kcufff at work
**edit: I've also got a spare inline fuse laying around - 40A. This would be good to use right and where do you think I should place it in the circuit? Thanks..
-2 amps
