Doesn't look like JL 250/1 has inboard fuses. Do i need to fuse near amplifier?
30a fuse should be fine
edit: if it is running of the stock battery you should have a fuse put no more than a foot after that, if so you don't need one before the amp.
Are you running multiple amplifiers? If not than replacing the primary fuse under the hood is fine, but if you have a distro with multiple amps, you need that larger fuse for the main power line and then a seperate smaller fuse near the JL amp between it and the distro
At the battery, just fuse for the wire, not the amp(s). So if you have 4 gauge, fuse at 120-150amps. 0 gauge, 250-300amps. Then if your amps don't have fusing, simply fuse for them before the amp.
That way, your wire is fused for max capacity at the battery, and you can just change the amp(s) fusing whenever needed. Most amps have on-board fuses, so it usually isn't an issue and you can just fuse for the wire capacity at the battery and let the amps take care of themselves.
That way, your wire is fused for max capacity at the battery, and you can just change the amp(s) fusing whenever needed. Most amps have on-board fuses, so it usually isn't an issue and you can just for for the wire capacity at the battery.
That is a genius idea.
Weeznur32
Weeznur32
Seattle
murph
