(someone earlier said it made no sense).I think that will be it from me on this thread, as I'm just about to start getting made fun of
![👋 👋](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f44b.png)
Good deck choice, I was actually heckling you when you had that 2600 model listed and was thinking “wait! no love for cd’s?”
like that you went three way instead of cramming bullshit3.5’s in that dash Spot. Hopefully the distribution of midbass to that speaker isn’t so much that it rattles your front panel. If so I’m sure some sound treatment can fix it. Also 600 wattson deck for that sub is rad.
hope you’ll make a video and let us hear how it sounds.
I would amp the front speakers and run the rear ones off the deck. Assuming the deck has the option to turn the speakers on and off If you have rear passengers. You could also just use the fader and fade all the speakers to the front, then as a courtesy fade a little to the back. If passengers aren’t important enough to give music to, eliminate those back speakers completely.
Crossover will do all the distribution work on the fronts, run rears on hu if you can turn those off on the hu. If you can’t turn em off on the hu leave me disconnected.Can anyone tell me what to expect in terms of house power should be distributed with this configuration.
Would anything at all be running off the radio? Would all speakers be powered by the amp? Is there a certain distribution between the sub and the front package? Am I asking the right questions here?
Keep the sub in the back, you’ll benefit from it firing off that back hatch then to you. Ask you installer to soundtreat your rear hatch door.The plan is to disconnect the back speakers. The people who are riding in the back do not exist, except a dog sometimes. I would even give up floor room on one side for the sub, but I dont think it would fit anyways I dont know if stuff like that would add or subtract from the soundscape, I'll consult with the pro about that issue.
