Does my Big 3 look ok?
Did you do the big 3 to yours? If you did could you take a picture of the ground to the frame.
took this a while back. camera's broke so i can't take a new one right now. you can see where the wires go down though. it's directly below the alternator.
it's on the frame down towards the oil pan. not really that close to the alternator. look straight down in that space and you can see the frame below.
Found the spot, big question now is how did you do it, laying under the truck?
thats the engine block ground dude...he wants the batt to chassis spot....
yes. it's easier than it looks. there should be a threaded hole, but if not, you can drill one and make threads with a tap set or use a nut, washer and bolt. make sure you clean the metal up good.
heres where i grounded mine....if you look in your passenger side tire well you see 2 holes in the frame with 2 big *** bolts in them.....
i unbolted one of them with a 3/4 deep well socket and hooked the wire like this underneath....
**** it never looked so rusted when i was under it....a 03 too!! F Florida!
bose301s
I can break these cuffs
bose301s
Durham, NC
bose301s
