Does amp need retuned?
  • 4
RamLimited
Installers wired my subs to 4ohms at the amplifier, even tho told them to do it to a 2ohm load. They tuned it and I hadn’t realized for months that they wired it to 4 ohm.
So question is: if I simply rewire the subs into the amp at 2 ohm, do I need to retune all the amp levels, or is it already set to the loudness of the receiver? Meaning i wouldn’t have to attempt to retune it myself, and could simply drop down to 2ohm without messing with anything?
There is no way it could be rewired to 2 ohms if it’s currently at 4 ohms. I’m assuming you have dual 4 ohm subs, which makes wiring options at 4 or 1 ohm. Dual 2 ohm subs can we wired at .5, 2 or 8 ohms.
There is no way it could be wired to 2 ohms if it’s currently at 4 ohms. I’m assuming you have dual 4 ohm subs, which makes wiring options at 4 or 1 ohm. Dual 2 ohm subs can we wired at .5, 2 or 8 ohms.
Yes it absolutely can. And that wasn’t my question
So I guess what I’m being told elsewhere is that 2 ohms at amplifier, is the same thing as 4 ohms x2. therefore if that’s true… then I don’t need to switch anything. Is this correct?
You have to bridge those......lol, right Rob?
I see that’s funny lol yeah I’m a noob with a Google education. regardless are these 2 setups: the 4 ohm x2 picture that I have now, and the 2 ohm pic I wanted to do… they are or are not equal?
Yes. It’s the same 2 ohm load in the end. A mono amp just bridges the 2 4 ohm loads at the amplifier. Doing it inside the box on the subs does the same thing.
149
834
10
859
RamLimited
RamLimited
Columbus, Ohio
RamLimited
SlugButter
    May 4, 2024
slater
    May 2, 2024
