do you really need a panel remover tool?
If the car has a few years on it I find it more helpful to have some extra new panel clips on hand instead of the panel tool, older clips are brittle with or without the tool.
If you know where the clips are you don't need the tool, the tool just makes things easier. Also once you get the first clip loose, I generally just use my hands to pull on the door panel(be gentle). So the tool is kinda just to get you started.
Considering they are about 15$, doesn't hurt to have one.
+1. Just be gentle. If they break, oh well. A box of them is like $10 at any autopart store and if they are brittle enough to fall apart its probably a good idea to replace them anyways.
If you remove you panel frequently, then by all means buy the tool. But keep in mind regardless you are going to want some spare clips on hand.
For those who think a flat screwdriver is just as good as a panel remover, don't discount the mechanical advantage of having a blade on 2 sides of the clip. This is one advantage the panel remover has over a screwdriver. In my opinion anyone doing installs frequently needs an assortment of panel removal tools of a variety of shapes.
crreed55
crreed55
CT
trumpet
