Do RCA's have a wattage measurement?
Drowsy
Side Effect
Just like power and speaker wires (guages), DO RCA's get rated and if so, what do I need to run
Polk Audio 5” dB501 Coaxial Speakers
Power Handling (continuous) 45 w
Power Handling (peak) 135 w
Audiobahn 3.5” AS31Q Coaxial Speakers
Power Handling: 60 watts RMS
to a
1 Polk Audio C400.1 4/3/2 Channel Amp
100W x 4
No make or model number on it? Do you have an exact picture of the rear and all its glory?
684
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
676
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
595
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
756
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
903
Drowsy
Side Effect
Drowsy
Pennsylvania
BrianChia
    May 18, 2024
    May 18, 2024
