Do I NEED a new alt/2nd battery?
I would add a seccond battery, because it will be MUCH cheaper than putting a GOOD alt on your vehicle. You are not going to find a decent high output alternator for your vehicle for much less than $500. I realize that there are many companies that offer an "overwound" toyota alternator, but they will all have the same or signifigantly lower outout at idle, due to the small size of the case. In order to increase the output at lower engine speeds on that vehicle, you would need one of our large case conversion kits, and that would run you $499.
Adding a seccond battery would improve the voltage drop (for short periods at a time) and your stock alternator will survive as long as you excersize common sense when playing the system. As long as you only play at high volume levels for a couple minutes at a time, and turn it down periodically to give the alt time to bring the batteries back up, you should be fine.
We have some open-box specials on Powermaster suplemental audio batteries if you want to add one for cheap. They are much more effective than an optima. Shoot me a PM if you are interested.
i added a second battery that we use for the phone company to start up our diesel back up generators. don't have any dimming problem at all and it stays at around 13.5 at idle with everything on. try another battery first,alot cheaper
I talked to some people at work and they said i can bring it into a shop and let then bed a new regulator or sometimi to give it a small boost in its amp output, should i try this along with the new bat?
yeah what he said...i can bass race with my aq 2200d, with a d5100r in the front and d3400 in the back and reving my 80a alt to 2k, my voltage stays right around 13.7-13.8
Is it possible to increase the amp output of a stock alternator by changing the regulator? Thats what a friend at work said. is there anything that can be changed? BTW I found out the stock is an 80 amp alt.
PuZo
PuZo
Toronto, Canada
PuZo
