Do I have enough room for 2 AQ SDC2.5's?
500rwhp
Was originally going to go with a single HDC310, but am wondering if 2 SDC 2.5 10's would be a better bet...
Going to be running my sub(s) with a 2200D.
I have around 33"x16"x10" to work with, and want to use a kerf port.
Would really appreciate any advice!
PM sent... Not sure how much exposure the guys at AQ are looking to get on this... Had no intention of letting the cat out of the bag...
Like I said, four SDC2.0's or one HDC3
also, why kerf when you can aero port, and get the most out of your three cubes?
Honestly, as bad as it sounds Ive always liked the 'look' of kerf ports.. Its going to be showing through my ski pass... Hoping a kerf port will work about as well as an aeroport. Also Im pretty sure Ill have closer to 2 cubes.. Thats why I was thinking I may not even have room for 2 SDC2.5s..
I don't think you have the room for 2 10s with a kerf port to be honest. I came up with just over 2.24(ish) before sub/port displacements.
I would suggest running the HDC and use areo/precision ports to keep port displacement down, but with the 2200 you would need to be careful with out you set your amp up to ensure you don't harm the sub.
And yes the 2.0 is on easter sale right now as well as the AQ750, I posted it up here some where.
Thanks for the responses guys. If space wasnt an issue, would 2 SDC2.5's outperform one HDC3?
I have at most 34.5" across and 17" in height.. How deep would the box need to be to accommodate the subs and other displacements?
How would you guys say a single HDC3 would compare to 2 SDC2.5's?
Also does a kerf port require more space than an aero port? Any more risk of port noise?
first off he doesnt have 3 cubes. he has 2.25 which isnt enough for a pair of 10s ported.
so just get the single hdc3 and call it a day.
beat me to it rabbit.
forgot to factor in wood thickness //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
500rwhp
500rwhp
Raleigh, NC
T.I.K.
