DLS A3 Feedback?
JISINSANE3
1995 dodge stealth r/t
Any feedback on this amp is appreciated. I know nobody that has even heard of this company but I did some research on it and it appears to be a HQ amp. I just picked up a DLS A3 for $100. I see on google there are 2 versions of the pcb. Mine is the one with the gold coated bus bars or whatever you call them on the pcb. I never seen such detail in quality on a board and there own CAPS! Its a dual mono block. Would this be a good amp for powering a sub or more for mids ? Its not all that powerful spec wise at 4 ohm to 2 channels but I believe the specs are underrated. I am building 2 systems currently. I did a search and could not find much feedback on this amp here.
only thing it says on the bottom cover is a sticker that says DLS symbol ultimate a-series, A3 The Twin I assume monoblock its scratched, CE a product from dls Sweden with a Swedish flag
Number of channels 2
Amplifier class AB
Mono bridge mode 1.33 ohm 1000 W RMS
Mono bridge mode 2 ohm 870 W RMS
Mono bridge mode 4 ohm 550 W RMS
Output power in 1 ohm 2 x 425 W RMS
Output power in 2 ohm 2 x 270 W RMS
Output power in 4 ohm 2 x 150 W RMS
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Input impedance, high level N/A
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
Frequency range 10 Hz - 50 kHz
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
Low level output No
External cooling fan terminal Yes
High level input with auto start No
Dual DC inputs Yes
Power consumption (idle) 1,1 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
very nice class/ab amp
woah, 140amp draw! Looks like Ill need a battery or 2. So this is on par if not better than a JL 1000/v2? I see it has a nice damping factor. Ill probably use it as a subwoofer driver since the power increases so much on 1 channel at 1.33 ohm. But why 1.33? I wonder why not a 1ohm full like most amps. Glad I passed up on the JL 1000/v2 for $450 for this.
Yeah but for price $450 vs $100, I did not loose. Some specs are better on the JL while others on this is better, But the 2 are different breeds. Class D vs a/b. I thought this was a D. The internals of the JL look impressive. But again price. Thanks for the insight. Anyone else want to throw in there 2 cents on impedence? Has anyone ran this at 1ohm ok? Ill have to get a resistor to up it to 1.33 if not. Im not taking any chances on this amp.
DLS specs on this are under rated by a good bit.
If you tune your amp right and after all of the dynamics of music and imp rise you will be above 1 ohm.
JISINSANE3
JISINSANE3
orlando fl
JISINSANE3
