DIY Brake bypass wiring
infamous_e46
hArRy_DaNgLeRs
can someone draw me a diagram my computer is bein a queef
here is a pic what wires go to what
thanks guys
ive got the same hu and i just wired it up alot easier way than this. just wire the ground too a toggle switch then that to a ground. flip the switch and you're good.
85 - bu/wt remote turn on wire
86 - ground
30 - ground
87 - l. gn e-brake input wire
only works on 3200/4200 series pioneer's
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
vegang
vegang
