Distortion on mono amp at low (1/4) gain
  • 4
sparten576
Hello,
I have an MRV-500 from alpine that ive had for a few years decided today i wanted to retune my amp since I haven't done it for a while and it was sounding odd.
I set head unit to max volume (doesn't clip I checked with oscilloscope) and played a -5db 40hz tone. I was amazed how much disortion and clipping there was as I was measuring the outputs with scope. I had to turn the gain down to 1/4 to get rid of all visible distortion to the sin wave.
This seems really low to me... Could the amp be damaged? Input preamp was 6V. Didn't remember the output voltage.
Thanks for the help!
That is the best you will get out of the amp. Another user told me that one can reach full gain even at 1/8 of the way because the input signal could be quite strong. Most audio companies suggest radio volume 3/4 up regardless. I guess that is for better headroom, but that is beyond my knowledge. I just apply what others have succeded with.
If your sending 6V to the amp yur gain will generally be low. Gain is not a volume its an adjustment to match input signal to output so higher in lower gain will be. Gains are set high usually with lower preamp voltage head units.
Thanks for the tips. I read the scope wrong It was 6v pk-pk so 3v peak. I ended up getting a 600 watt version of basically the same amp and I'm getting decent volume now.
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
948
Hey guys, anyone with a DD-1 or other distortion detector in the south florida area ? Thnks
The amplifier will only amplify the waveform that you put into it. I think you have missed or are misinterpreting something here.
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
903
sparten576
sparten576
Minnesota
sparten576
slater
    May 2, 2024
slater
    May 2, 2024
