Help needed to identify the cables - Chinese head unit
avi
CarAudio.com Newbie
8
Hi. I'm sure that the members have much more experience than I have and I hope that you will be able to offer help identifying these cables on the loom of a Chinese hu kit that I've purchased and would like to install. the black cable on the left- marked no.9- is separated and have a different connector, not the rca type. no 3 and no 4 are the only ones that the manufacturer was kind enough to write on the label in English. they are marked "aux r in" no.3 and "aux l in" no.4. they are the only two that I know what they are for. all the others are an enigma . looking forward for your help.
One more thing that I would like to ask - there is in the kit a reversing camera. I understand that it's powered from the reverse lamp. is it allowed to connect it directly to the wire delivering the voltage to the bulb, or do I have to use a relay since as far as I know the vehicle (2012 Toyota Yaris) has a Canbus?
Thanx.
Thanx for your reply. all of them with the exception of no.9 and no.5, are with RCA connectors.
btw - what is the thin gray wire no.5?
Hi. thanks to the help I received so far, part of the mystery resolved. what I've found in the kit, that there is additional cable for the reverse camera and there is a dedicated connector for it on the unit. thanx to advice given by dragon.breath, I learnt that the Chinese writing on the label, above the "camera" says that it's the reversing camera. now, as you can see in the picture attached - there are two short blue wires with white strip, my guess this wires somehow controls the mode of the display, turning it to show the content provided from the camera. any idea how and to where these wires should be connected? I guess that it have to be connected some how to the voltage coming from the reverse light when the selector engaged into "reverse" position.
Thanx.
avi
CarAudio.com Newbie
avi
avi
