port back subs up was the first thing i did. The port was only a couple inches from my tailgate and this loud irratating voice came from the tailgate everytime the subs hit. So i had to switch it up.....Mount the amp on the side of the box near the battery. And if you turn the box around to have the ports face back, it should sound better and be a little louder.
no wonder it sounds like ***, you're getting mad cancelation manport back b1tch.
port back.
you're running tons of power to a beefy setup, shit's gonna vibrate anyway you cut it. Go in there with some duct tape and/or foam and psuedo deaden it.port back subs up was the first thing i did. The port was only a couple inches from my tailgate and this loud irratating voice came from the tailgate everytime the subs hit. So i had to switch it up.....
i had a slimular problem with my kx2500.1 where the belly of the amp would slap the box since the only screws holding it down were the outside corners. buy some foam weather stripping with adhesive on one side and stick those to the back fo the amp. it'll keep the parts that the screw points cant really help....I'll most likely slap another piece of MDF with some cushion and rubber spacers
If you are getting 'voices' played through your subs, your xover settings are fvcked up.port back subs up was the first thing i did. The port was only a couple inches from my tailgate and this loud irratating voice came from the tailgate everytime the subs hit. So i had to switch it up.....
i should have said noises. I did not say the subs were making this noise, the slapping tailgate is. So i flipped the box around and took down backseats....If you are getting 'voices' played through your subs, your xover settings are fvcked up.
I concreted my blazer's tailgate.i should have said noises. I did not say the subs were making this noise, the slapping tailgate is. So i flipped the box around and took down backseats....
