Beermakesmehoppy
I have a dimming problem. Here is what I am running:
02 Ford F250 5.4L CrewCab ShortBed
Mechman 250A Rhino Alt
Optima YellowTop (that's been through 3 burnt out Alts)
1 Fi BL 12" @ 1 Ohm
Diamond Audio D6 1000.1
Diamond Audio D6 700.40
2 sets Polk Audio DB6500 Components(1 pair in front, 1 pair in rear)
I have 1/0 gauge running to a Streetwires 4ga. AGU fuse distro block which is ran to each amp.
1) Is the wire thick enough?
2) Should I get the battery replaced?
I've been told to get another battery primarily for my system.
3) If I do this, will I need to upgrade the Yellow Top also?
4) How will a second battery stop the dimming if the Alt is producing the same amount of power?
1 Fi BL 12" @ 1 Ohm
