Capacitor or Capcell?
romeostylez13
18
NJ
Im just trying to put a system together for my new car. The amp specs and subs specs below, which im going to order. Ordering the 2600watt 2 channel amp and 2 12" subs. Not sure if i should pick up the capcell that i have listed below or a capacitor??? No clue at all what would be better. Any recommendations would be great!
Power Acoustik BAMF2600/2 Amplifier
Dimensions 2.2" Height x 17.1" Width x 9.2" Depth
Channels 2 Channel
Output Power 2 x 450W RMS (10Hz to 30kHz) @ 4Ohm
2 x 540W RMS (10Hz to 30kHz) @ 2Ohm
Manufacturer Website Address http://www.poweracoustik.com
Additional Information Line output
Platinum RCA and Screw Terminal Connections
High/Low Level Inputs with Floating Ground
Tri-mode Capable
Power Acoustik P3-12W2600W Max, 12" Dual 2 ohms P3 Series Subwoofer
Power Handling:
Peak: 2600 watts
RMS: 1300 watts
Polypropylene injection molded cone woofer
Butyl rubber surround
Poly cotton spider
Texture coat finish on stamped steel basket
KSV Kapton voice coil
Nickel plated 8 Gauge compression wire terminal
Suspension integrated tinsel leads
150 oz. Magnet structure
Sensitivity: 83 dB
Power acoustik capcell-600 600-Amp capcell???????????
Surge 600 amp X 5 seconds
.25" bolt terminal
.005ohm
5 amp/Hour
36 year cycle life
Digital volt meter
Led display
16V DC
Satin chrome finish
why not get the monoblock bamf amp? youll get more power to ur subs.
you dont need a cap or capcell. just do the big 3 upgrade and then maybe get a bigger/ better batt for under the hood. but for that amp, just the big 3 should be fine
from the product I am assuming you are buying from Sonicelectronix. dont buy a cap cell scroll down or up and get the hc600 or the bt20, and definately get a 1 ohm monoblock amp as well. also get the dual 4 ohm subs not the 2 ohm subs. if you want better stuff, shoot me a PM and tell me the prices you are paying on this stuff and I will get you a better brand product for the same or less, or tell you what product to buy from where ever you want.
I hope your trollin.
Shy away from PA.
that amp is only rated at 1200W and it prolly wont do rated.
The subs wont handle rated power either most likely.
those subs are 1300 rms and since it is all brand for brand they should be fine. now if that was an HF or RF or saz ect i would say no way //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
romeostylez13
romeostylez13
NJ
romeostylez13
