Sold Digital Designs Z1
Grim
Resident Electrician
If you really want me to post specs I guess I can. But I assume if your buying an amp of this caliber, you already know what it can do.
Theres two up for grabs however, I would like to keep one.
Almost brand new. Used for about a total of 5 seconds(burps) in a comp
1500obo...
And I do mean or best offer...
Note, These are also for sale on CAF...So its pretty much first come first serve between the two forums..
Also, I didnt use them...I prolly would have ruined them in the process.
Ok no clue on the revision, all I know is they were the very last amps made before production ended(not the acuall last amp off the line, but the last design) They have the platinum terminals instead of gold...
these amps are 1500$ BNIB.... that is what he paid shipped from DD..... if he says they are the last production ones... that means they are the ones fixed with the fixed mobos... IE the best ones!!!
Digital Designs Z1
1 x 3000W @ 1 ohm (14.4V)
Efficiency:
Dimensions: 24" x 12" x 2.76" (610mm x 285mm x 70mm)
Bench tested by Peter.T from Soundpressure.com (Sweden):
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14,4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
Digital Designs Z1
Efficiency:
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14,4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
****, I really didnt know they were THAT under rated.
Grim
Grim
Western NY
Grim
