Digital designs ddzse
cal
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gifItem(s) for Sale:
AMP IS NIB NEVER BEEN USED OR INSTALLED ONLY TESTED WHEN IT ARRIVED TO INSURE NO DAMAGED ACCURED DURING SHIPPING .
AMP DOES HAVE A TINY FLAW ON THEN SIDE OF THE HEATSINK I HAVE POINTED IT OUT IN PIC # 39 I NEVER TOUCHED IT UP OR MESSED WITH IT . IT DOES NOT EFFECT PEFORMANCE I JUST KNOW ITS THERE AND FIGURED ID LET YOU KNOW .
AMP COMES WITH BOXES,ALLEN KEYS, REMOTE GAIN ,CABLE ,OWNERS MANUAL,AND DD TEST SHEET
with out arguing this is straight from dd, amp has same output as a ddm4a exept its built stronger to handle lower ohm load and obviously its a limited edtition pc .
these are off dd site for the ddm4a
Bridged NA
Channels 1
Cont Power at 1 Ohm 5200W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Damping Factor >150
Dimensions (Inches 27.625L x 9.13W x 2.5H)
Dimensions (Metric) 702L x 232W x 63.5H
Dynamic Power 9500W
Efficiency Thru Output 87%
Input Sensitivity 0.15v - 5v
hipping Weight 36 lbs
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable High Pass FilterNA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
1385 SHIPPED AND INSURED
CON U.S ONLY AND NO TRADES .
PAYPAL EXEPTED
http://www.caraudio.com/forums/member.php?u=1006316
here are the pics that show the difference from the ddzse and the ddm4a
1st pic is the ddm4a second pic is the ddzse not mine just a gut pic of one
cal
cal
cal
