1. Digital Designs C4a
2.
Specs:
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 5 kHz at 18dB
Variable Low Pass Filter
50 Hz - 5 kHz at 18dB
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
C4a
Cont power at 4 ohm
100W x 4ch
Cont power at 2 ohm
150W x 4ch
Damping Factor
>250 @ 2 ohm
Cont power at 1 ohm
175W x 4ch
Cont power at 4 ohm Mono
300W x 2ch
Cont power at 3 ohm Mono
350W x 2ch
Dynamic Power
400W x 2ch
Efficiency thru Output
>65%
Dimensions - mm
380 L x 235 W x 53.4 H
Dimensions - inches
14.96 L x 9.25 W x 2.1 H
Signal to Noise
92 d
3. Description/Condition:
Bought from a member here in January, I'm selling off everything so it needs a new home. Amp is in great condition cosmetically and no issues mechanical . This is a fully active amp and stable down to 1 ohm per channel. i do not have the manual or original box.
4. $200 shipped (no trades)
5.
2.
Specs:
Input Sensitivity
0.2V - 8V
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
C4a
Cont power at 4 ohm
100W x 4ch
Cont power at 2 ohm
150W x 4ch
Damping Factor
>250 @ 2 ohm
Cont power at 1 ohm
175W x 4ch
300W x 2ch
350W x 2ch
Dynamic Power
400W x 2ch
>65%
Dimensions - mm
Dimensions - inches
Signal to Noise
92 d
5.
