Soundqubed 2200D
jason4g63t
One soundqubed 2200D purchased 3/23/2014 was used a month then my transmission went bad in the car and has not been used since then.
Specifications
Model Q1-2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
Mint besides one blemish on the face
375obo
Shipping will be at buyers expense will come as it did in box from soundqubedView attachment 26548966View attachment 26548967
jason4g63t
jason4g63t
lima ohio
lose_money
