Sold Digital Design Z1A Amplifier - $950 Shipped.
Tinted
This amp is NO JOKE. If you want real power this is the amp to get. No over rated BS power specs with this amp.
1. Product:
DD Z1A Amplifier
2. Specs:
Full specs can be found here http://www.ddaudio.com/dd/amp/amp.asp?series=Z
3. Description/Condition:
Used in very good condition. I've only used it at 1 ohm for music for a few months. Tested to do OVER 5,000 RMS in a CAR. Did this test myself, no BS bench testing with resistors here. It did 5,000 watts hooked up to a pair of subs running off of 1 battery.
4. Price: :
$950 Shipped in con US.
5. Pictures:
what i ment to say is that you dont hook up resistors to your amplifier outputs when it's in your car. you actually use speakers, right? That's how i tested it.
I have 250 alt with stock battery, will upgrade battery soon. What would you suggest, powermaster 3000 or batcap 3000?
Powermaster 3100, Stinger 2150 or NSB-g3100, next to the amp with the stock battery under the hood!!! Then you should be fine. But with all that power, 2 ohm load should be good enough!!!!!!!!
Tinted
Tinted
Toronto, Canada
danyopjr
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
