Here are the specs on this amp from Ultimate's website:
Bridged Output- 4 Ohms N/A
Output Power- 1 Ohms 1,300 Watts RMS
Output Power - 2 Ohms 900 Watts RMS
Output Power - 4 Ohms 500 Watts RMS
THD
Signal to Noise Ratio >90dBA
Frequency Response 15Hz - 250Hz
Bass Boost Remote, Variable, 0-18dB @ 45Hz.
Low Pass Crossover Variable, 50Hz - 250Hz, 24dB/Oct.
High Pass Crossover N/A
Band Pass Crossover N/A
Sub-Sonic Filter Variable, 15Hz - 50Hz, 24dB/Oct.
Protection Thermal/Short/ DC/Cross-Wire/Fuse
Dimensions/mm 401 X 269.2 X 50.8
Dimensions/inches 15.75 X 10.6 X 2
Here are some quotes from reviewers that aren't stated in the stats, but influienced my purchase:
With overall efficiencies of 80% or more, and fully regulated power supplies, these digital power plants really deliver. Unlike conventional "High Current" amplifiers that waste as much power heating up your trunk as they deliver to your speakers, the Digitalis Amplifiers keep their cool and put the power to work where it does the most good- Moving those voice coils!
Quite the sleeper amp. It's rated at a mono output of 1200w RMS into 1ohm, however the output is more like 1400w RMS on the bench.
. Using pulse width modulation techniques, these new amplifiers make it possible to deliver enormous power to your speakers and do it efficiently without the need for special high power alternators or a trunk full of batteries.
I really enjoyed reading your dialogue about the advantages of class d vs class a/b, however, I still haven't gotten my "Amplifiers And Subwoofers For Dummies" book off barnes and noble yet, so I'd like someone to awnser these questions in a simple non-technical manor.
1. Are Ultimate Sound amps worth a ****? *PLEASE NOTE* Do not awnser this question if you don't own or have owned an ultimate sound amp. Nothing pisses me off more than replies where someone says "Well, my buddy had this amp and it sucked" You'll never know the full potential of an amplifier until you own it and have time to play with it.
2. How many amperes will this thing draw if it puts out 1200w RMS @ 1 ohm @ 80% efficiency? Will her stock 110 amp alternator keep up with it?
3. WTF is "Pulse Width Modulation"?
4. Is there anything I should know about maintaining/installing a class D over the class A/B's I've owned in the past? Is there any real physical difference?
5. Do class D's tend to clip more than a/b's? The last thing I need is some clip-happy amp ruining my beautiful 'bahns a week after I install them.
6. This one is especially for Lloyd: What subwoofers work best as hats? I tried a Kicker L5, but it clashed with my shoes. I tried an Audiobahn piston, but it kept falling off. The shocker 2 fit nicely, and it even matched my outfit, however the 60lb magnet caused undue neck strain.
