Different ways to finish subwoofer boxes?
Fiberglass and paint, fiberglass and vinyl, carpet, leather, suede, flock but it would take alot, laminate, build out of birch plywood and stain for a woodgrain look, plexiglass, SEM spray texture to match factory colors
It is alot of work but I didn't wet sand or buff this box
WWWWAAAAAAAAYYYYYY TOO MANY STEPS!!! It doesn't take that much work to paint a box man.
I'd actually confidently say that's not enough steps. It can take far longer to finish the enclosure than to build it if you want to do it properly with only having OTC materials.
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
THXdts
THXdts
Maryland
PV Audio
