sundownz
Pro Seller
Supporting Vendor
While I am with you that any modern unit pretty much sounds passable at normal levels, but when you push many of these units hard to the point of their rated power output the THD can easily reach unpleasant levels.Only if there is an [audible] difference in distortion/noise or frequency response (and a difference in frequency response is easily "fixed" with an EQ). And most any amplifier produced today will have low (inaudible) amounts of THD+N, especially in a subbass application where distortion is harder to identify.
This has proven to be the case with the inexpensive HiFonics units that reach levels of 10% THD to achieve rated output power. Combine this with the THD of a subwoofer at that amount of power input and you have a level that is easily detectable even with subbass.
If you still do not agree that this is true compare something like a Lanzar Vibe 1200D to an expensive Class-D such as Xtant X1001 even at a moderate level. I think alot of the problem is that many manufacturers skimp on the MOSFETs used in this design, not taking into account the special needs of a Class-D design and/or not caring for cost reasons.
As to the earlier mention to RCs test, it has no relevance here. His test is to show that different topologies will sound the same if their response is equalized and THD is even -- that is a no brainer. In a fully built retail amplifier unit these factors are NOT equal between different models. Amp A may have 10% THD at 1000 watts whereas Amp B has 0.1% THD at 1000 watts, you have 1000 watts in both cases, which one do you want?
