so i used to have a 15" L5 and i just got 2 12" L7's. they both handle 750 rms but the magnet on the 15" was alot bigger then the magnet on the 12's. why is this? if they both handle 750 rms shouldn't they have the same size magnet?
About the only thing that's true about magnet size is that the bigger it is, the heavier it weighs and the bigger it is, the more heat it can absorb. That isn't going to change the power handling though as that will be limited by the coil, former, coil glue, suspension, and motor cooling techniques.
Magnet size also tells you NOTHING AT ALL about how the driver will perform. The only reason why it's mentioned in spec sheets is because it's a good marketing tool for the people who know nothing about how drivers work.
Spot on.Thermal power handling depends on voice coil material, size, and type.Mechanical power handling depends on suspension material and geometry.
Magnet size does nothing for power handling
Actually, the speaker's ability to cool itself also plays a big role in its thermal limits. The W7 and DD9500 are two examples of subs that have had substantial engineering gone into their cooling features.Thermal power handling depends on voice coil material, size, and type.Mechanical power handling depends on suspension material and geometry.
That is true.Actually, the speaker's ability to cool itself also plays a big role in its thermal limits. The W7 and DD9500 are two examples of subs that have had substantial engineering gone into their cooling features.
