Did I wire my comps right?
are they in phase? what comps, and what amp? what music... mp3 or cd? more info please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
make sure the positive output from the amp is going to the positive input to the crossover, and the positive outputs from the crossover are going to the positive inputs to the woofer and tweeter. same for negative.
i'd try switching the + and - for ONE of the speakers at the amp and see if that helps. not both speakers. it's either going to make it sound 1000% better if you wired them up backwards, or 1000%worse if they are wired up correctly. if it sounds worse that way, then there are other issues that can be addressed.
I wired them to the factory wiring in the door, found the same wires behind the head unit, connected those wires to the crossover, then ran wires to the amp. They don't seem to be performing that great....
If I'm understanding this correctly, you connected the wires from the back of the HU to the crossovers?
No, the HU is only running the rears. The comps are hooked up to the factory wiring to the HU, but I think my dad took those wires from the HU, hooked them to the crossover, which is then connected to the amp. Is this right??
It should be wired like so:
HU FRONT SPEAKER CHANNEL OUTPUTS --> LOC/AMP INPUTS
AMP OUTPUTS --> PASSIVE XOVERS INPUTS
PASSIVE XOVERS OUTPUTS --> MIDS AND TWEETS
thepope3290
thepope3290
Thomson, IL
DejaWiz
