did i blow my sub ?
zenkar
So i was messing around wih my box the other day.. i was playing with the
Gain and i put it a little bit higher and was playing music for about 20 minutes
and then the bass was cutting out once in a while and now its not hitting as hard as before
so i lowered the gain (its at 1/4 now) and the sub is still playing but not like it used to..
i turn the volume up a little and it sounds like duh duh duh... seems an amp settings is messed up maybe?
So my amp settings at the moment are LPF = 12 HPF= Off Phase= 0
and my HU settings are all at default..
that can't be right, your lpf should be a frequency number, not 12 24 and full. i am not fimiliar with that amp, but maybe you are adjusting the wrong thing?
what should the slope be at? also i have a switch that says Copy/Gain/Master any idea on what it should be on =P sorry for newb questions
thanks for the responses! i remember last time this happened i fooled around with the 12 24 and it worked! HPF should be off? phase off? and wtf is this Intelli Q knob =;/
zenkar
zenkar
new jersey
zenkar
